FM 117” kit with S&S 475 cam build
#61
Running hard is not easy to define as it may mean one thing to you and something else to me. So what needs to happen is keep the engine under load then remove the load for a period. No need to go WOT to do it. On a Dyno it's easy to control these things but on the street I like to use a longer hill. Keep the bike accelerating as you go up the hill then let it decel down the other side. The decel puts the lubrication back on the cylinder walls and pistons while the load up the hill pushes harder on the rings to seat them. You DONOT want to run down the highway at steady speed.
Why do you think the MOCO doesn't use this in their break-in procedure? After all, they designed and build the bike. With your method, we could stay within the MOCO's recommended parameters and still properly and effectively run in our new motors. The reason I ran in my new M8 by the book is that this is the first new anything I have ever had. I didn't want to be denied a warranty claim on the basis of improper break-in. Staying within those narrow parameters I was able to run in this engine with every varied condition you could think of including your hill method. NO LUGGING and NO STEADY SPEEDS!!! Now, I can give a rats rear about any warranty; because, nobody is touching my bike.
#62
I guess I can't say I followed the "hard" break-in to the T. When I applied this method to my Roadster and Fat Bob, I would describe it as a mix of by the book and this method. No WOT but definitely didn't putt around like the manual says to. Varied speed and had plenty of acceleration along with deceleration to work those rings.
The Roadster definitely had a noticable difference in power over my 48 and my Fat Bob feels nice and strong but I have no comparison for it. I like the hill suggestion as well Steve.
#63
#64
What tuner are you running. Also does your bike run real rich at idle
#67
#68
Ride safe!!
#69
Their is a 475G cam for sale for great money in the multi fit for sale section as this is a 475 thread.
https://www.hdforums.com/forum/multi...it-for-m8.html
Peace
Peace
#70
