FM 117” kit with S&S 475 cam build
Old 12-24-2018, 10:36 AM
Trainwreck43's Avatar
Trainwreck43
Trainwreck43 is offline
Wow that’s awesome. Thanks FuelMoto! Done!
RinTin (12-25-2018)
  #42
Old 12-24-2018, 12:00 PM
Trainwreck43
Boom. Record time. Cylinder gets over-nighted Wednesday.
RinTin (12-25-2018)
  #43
Old 12-24-2018, 04:51 PM
el chivito76's Avatar
el chivito76
el chivito76 is offline
Are you doing the work yourself? Are you upgrading oil pump and cam plate? Cam bearing?
  #44
Old 12-25-2018, 02:13 AM
NerHD's Avatar
NerHD
NerHD is offline
6th Gear
Tag for info, just did the FM 117 kit with the Wood 22x cam on my softtail.
Trainwreck43 (08-16-2019)
  #45
Old 12-25-2018, 11:08 AM
Trainwreck43
Doing the work myself. Not doing the upgraded oil pump & cam plate this time around. I am replacing the cam bearing.
  #46
Old 12-25-2018, 12:00 PM
rdc401's Avatar
rdc401
rdc401 is offline
I’ve got the same kit with 22x cam have you put it on dyno yet.going to start on mine tomorrow putting it together.
  #47
Old 12-26-2018, 09:56 AM
el chivito76
Did you buy the cam tools?
  #48
Old 12-26-2018, 09:27 PM
Trainwreck43
Congrats on the kit, RDC401! Keep us posted on your 22X! I plan on having mine Dyno'd, but my tuner is suggesting I put 500 miles on it before I have it tuned.
I did buy the cam tool. Hopefully this makes things easier.
  #49
Old 01-10-2019, 08:03 PM
JABFLHX's Avatar
JABFLHX
JABFLHX is offline
Trainwreck43....Have you had a chance to dyno this kit yet...I am in the process of helping a friend put his in with the exact same cam as yours...Was just wondering what kind of numbers to expect...I know exhaust and breather can make a difference....but was just wondering what kind of ballpark numbers we are looking at....Thanks in advance
  #50
Old 01-12-2019, 06:49 PM
Trainwreck43
Had a delay due to chasing an intake leak. Found it and completed the build today. Test ride is tomorrow. My tech says I gotta put 500 miles or so on it before I Dyno it, so it make be another week or so before I do that. Also, I have some extra valve train noise, so I may take the pushrods and lifters out and try that again. Other than that, sounds good so far!
Quick Reply: FM 117” kit with S&S 475 cam build
