V&H Dresser Duals w/114??
I have dresser duals with 450 raiders on my 107. Love the look. Yes kills torque but I added the thunder torque inserts and gained some low end grunt back. I have not had on a Dyno but plan to run it on one over the winter.... From going by my fp3 I gained 14ft/lbs back. Not sure how accurate that is but that is the live data on the app. The but Dyno definitely felt the difference.
I will be very curious to see your results. I am doing the Andrews M462. Thinking of doing a power vision tune and leave the fp3 behind. Not that I am disappointed with it. Just not sure how well it will adjust for the cam. I have more confidence in a proper tune. What tuner are you using?
Hopefully you have it tuned & dynoed I'd like to see the #s with that cam. I like the timing events on that cam, on paper I think it could be one of the best cams for an otherwise stock 107, the one test I've seen it had really good TQ right at 2K & pulled well up top also. I'm not sure you'll find a good tuner to use the FP3, they have less capabilities & are harder to to use on the dyno, find a good tuner & use the device he likes to use. If you find someone using DJ PV you can just buy a tune license from him for $200 & you don't have to buy the tuner itself, I think you could still use your FP3 to monitor conditions.
Yes I will be using the power vision as that is what my tuner prefers. I will be buying just the license. I have seen 3 Dyno graphs on that cam and they seem good, very flat torque line. Comes on early and holds. So we shall see. I was wondering about plugging the fp3 after the tune to do just monitoring. Curious if anyone has done that. I just don't want to plug it in and screw up a good tune.
