Decent sound with stock headers?
#31
I had Rinehart 4.0 slip ons and they sounded good when someone else was riding my bike. I could really hear the sound then but while I was on the bike I didn't care for them. I put a Thunderheader on (of course, always been a TH guy) and I love the sound while riding the bike. It's louder than slip on's, but I like it. I don't play the stereo or try an d talk to the person riding next to me. Not any louder than the guy going down the road blasting his radio loud enough that he can hear it. But just as many people will hate the TH so there ya go. To each there own and there is just no way to ever answer the question of which sounds best.
#32
hows the performance. The M8 TH seems to be built for larger motor builds. I’ve always been a TH guy but was worried about over pipeing the M8.
#33
I wouldn't hesitate to void the warranty and make the same change again. The Billet Cat might do the same thing but I just don't care for the sound. Tried it a few times and just never made we go wow.
Having Zippers 468 and a Dyno tune done Wednesday. I will have before cam dyno and after cam dyno done to compare the two. Didn't get dyno totally stock so can't say what those numbers are but I was really impressed. Wife and impressed and she is usually clueless and power.
#34
I hear a lot of people cutting out the cat and welding the pipes back up. There’s ads on CL to exchange pipes. Had my bike dyno tuned, he told me the factory pipes are better than true duals when it comes to performance.
now we have to start a thread about voiding the factory warranty.
#36
Gary1 (01-23-2019)
#37
#38
#39
There is no reason to cut the stock header to remove the cat. I used this drill bit, $14 buck from Home Depot, https://www.homedepot.com/p/Bosch-1-...005T/204415336. I allows you to drill all the way through the cat. Drill holes as close as you can to each other around the outside edge until you can collapse the cat and pull it out. The pipe can stay on the bike, in fact probably easier to do if it does because it will be stable. It took me about 30 minutes to do this. I then took a long burr bit and cleaned up any cat debris left on the pipe (it will probably blow out as you ride anyway) and radiused the outlet to the left side so it didn't extend past the wall of the collector. That was something Steve Cole asked me to do before we did cam testing last year. This year I am going to a Fullsac X pipe, so we will see how that works.
I did not notice a big change in exhaust note. Not really worth the effort in my opinion.
Gary1 (01-23-2019)
#40
I've seen a bunch of guys remove the cat and the same look of disappointment on each of their faces. No improvement in performance and ZERO addition to noise output.
I'll give the best advice I can. Keep your stock system stock and change out the entire system with head pipe. Just in case say 3-5 years from now your state decides to comply with EPA mandates for motorcycles and the cops start pulling you over for loud exhaust, you can simply install your old system back on and get the ticket written off.
I've found (sound wise) nothing beats a transfer over to TH system. Gives you more TQ on the bottom and the sound is about as close as you will ever get to the old twinkie or evo. These motors are designed around exhaust noise and so you really need to get in there and change it up with either a cam or full exhaust to get the note you're looking for and remember.
Just my 2 cents.
Gary1 (01-23-2019)
