Tpms
Old 12-31-2018, 09:46 AM
Eltopia's Avatar
Eltopia
Eltopia is offline
Default Tpms
Has anyone installed tire pressure monitoring off a cvo model on a Limited.
Will the readout show up on info screen?
Will the 90 degree valve stem work on a Limited?
Thanks
Old 12-31-2018, 10:46 AM
show-n-go's Avatar
show-n-go
show-n-go is offline
My TPMS readout is on the gauges with the odo and trip. Then the warning light is up there with the check engine light. You should be able to see the cut outs in the speedo if yours has them already, if so they may just need wired up
I have a CVO so I can't help you with the other questions.
Old 12-31-2018, 04:55 PM
intrepidxc's Avatar
intrepidxc
intrepidxc is offline
In this thread you can see someone had the dealer flash the boom system to allow the TPMS system to function. Once that happens you need to buy the in wheel TPMS monitors ($160 + install) and it should work.
https://www.hdforums.com/forum/touri...ox-gts-20.html
Peter Quinn (01-01-2019)
Old 12-31-2018, 05:08 PM
Eltopia's Avatar
Eltopia
Eltopia is offline
Thanks I did a search but did not find the thread
Old 01-01-2019, 03:34 PM
Peter Quinn's Avatar
Peter Quinn
Peter Quinn is offline
He is not referring to this thread. Tap on the link above which he provided.Not a lot of info but I am also going to look into it!
Old 01-04-2019, 09:07 PM
wmprof's Avatar
wmprof
wmprof is offline
Received 1,262 Likes on 433 Posts
Stopped at the dealer tonight with the new 18 RGS to have my driving lights on with brights and rear speakers turned on. Asked them to look for TPMS in menu. Said it was there. Only question came up was he said CVO wheels have a slot or notch to index sensors. Not sure if standard touring wheels are same. Will let y'all know when I find out.
Old 01-06-2019, 10:55 AM
107inMO's Avatar
107inMO
107inMO is offline
"If" you are interested in after market, I like FOBO. App on phone let's me check pressure within blue tooth range. Also will send an alert to your phone if you have a loss of pressure . I replaced the valve stems with metal T Valve stems . Much easier to add air than with the stock ones.
Old 01-06-2019, 11:35 AM
107inMO's Avatar
107inMO
107inMO is offline
My dealer was checking to see if the limited radio would support the tpms from a CVO?
Old 01-06-2019, 03:54 PM
craigffb's Avatar
craigffb
craigffb is offline
The wheels having the notches for the sensors is gonna be the determining factor in this. The radio has the capabilities to support it.
Old 01-11-2019, 10:48 AM
Hd589's Avatar
Hd589
Hd589 is offline
Can the TPMS feature get turned on with the snap on professional tool or is this a dealer only type deal?
Quick Reply: Tpms
