M8 sumping test?
Not taking it in for the clutch slave recall. Bike is still under MOCO warranty for another year. I ordered the AIM Light Force II . Supposed to release/ship on 1/9 . I will install that myself. As I said I do not trust HD techs to work on my bike unless I'm forced to due to breaking down far away from home or a catastrophic failure.
Not sure I understand sleeping better once you do the test. The bikes dont sump until they sump. My first one didnt happen until 5600 miles, a few months after riding via highway back and forth from Sturgis from Detroit, often at 90+ mph and it was fine. So if I had tested mine at 3000 miles, I would have thought I was in the clear, according to your theory
Of all the things one of these bikes can break from, wet sumping must be way, way down at the bottom of the possibilities list. Much more likely to lose a wheel bearing, or drive belt, or water pump, or get a flat tire, or warped brake rotors, or blow out a spark plug that wasn't torqued properly at the factory, etc etc.
I've heard pulling the CP sensor just back from the water pump on the bottom of the block is a good test to check for sumping. My 2017 RGU has been level on a lift for 2 months. I removed the CP sensor today and had probably 3 ounces drain out. Would this be considered an issue or not? Thanks for any information.
It Depends.... how and when did you check your oil? You need to follow the steps in the owner's manual for checking your oil. To easily determine if you're sumping, follow these steps:
1) Measure the oil in your M8 engine following the procedure specified in your owner's manual. Your engine should be at or near full level. Take a picture of the oil level on the dipstick before starting step 2.
2) Ride the bike for about 75-100 miles with both highway speeds and higher rpm twisty roads, riding without significant stops or turning off the engine.
3) Use the same procedure in step 1 to measure the oil level at the end of step 2 without idling for any significant period at the end of the ride. Take a picture of the oil level on the dipstick at the end of the ride and compare to the first oil level picture.
A) If the dipstick oil level in step 1 equals or is close to the oil level in step 3, then your bike isn't sumping and is unlikely to sump in the future. Forget about sumping and enjoy the bike.
B) If the oil level in step 3 is down 2-4 rows of dots, then your engine may have a mild case of sumping as there is likely more oil in the crankcase than there should be. Its worth sharing your pictures and findings with your dealer.
c) If the step 3 dipstick level is very low (down to ADD OIL) compared to the oil level in step 1, your M8 engine has a serious sumping issue. The missing oil between step 1 and step 3 has collected in the bottom of your crankcase due to sumping. Share your findings and pictures with your dealer. It needs to be addressed before the engine fails as a result of sumping.
But, yeah, my ABS broke before I sumped.
