What FP3 setting for MagnaFlow Hitman on SGS 114"?
Anyone running the Hitman mufflers on the Street Glide Special (114") with an FP3? What setup are you using?
FP3 tech told me to use Eliminator 400 with standard baffle as my base map. I am wondering where they get their info from. I would think if they went through the trouble to test the mufflers there would be a selection in the maps.
On my 2017 sgs I started with the map for power duals and 4.5 high outputs (advised by vh), my stock header was decatted with hitmans. I then ran three 1 hour auto tune sessions and finalized the map. I uploaded the map to Vance and Hines for them to look at, they tweaked a few things and sent it back, I reflashed it and it ran great. Another thing that made a huge improvement for me was changing the throttle progessivity to either aggressive or race, I loved it. I would not use the eliminator map since they are 4 and the hitmans are 4.5, I'm sure it would be ok but why not use the 4.5 base map.
They told me high outputs for just the hitmans with stock header or use the power dual map with high oitputs since I was decatted
Here is the response:
Originally Posted by VANCE & HINES
We don't do dyno runs for every exhaust system, but since our exhaust product line is so expansive we have something that matches up well to nearly anything. We recommend the pipe that matches best as far as the diameter and baffle type, as well as rely on our experience with certain exhaust systems from 4 years of working with the FP3.
Regardless of the base map, thought you want it to start as close as possible, the motorcycle's ECU will be adjusting the map automatically over the first 1-2 tanks of fuel due to the FP3 clearing the adaptive fuel trims after each flash. So, theoretically, whether you start from map 'A' or 'B', as long as they're comparable you will end up with the same map after running a couple tanks of fuel.
Keithhu was spot on, as long as it's in the ballpark it's not going to matter.
4.5's, LoL
