Vance and Hines Dresser Duals (True Duals) Head Pipe
I am running the dresser duals. Bike had it when I bought it used. I like them but true duals will hit your low end torque. I did install thunder torque inserts from dk customm products. Base stage 1 run with torque inserts was 75hp and 100 torque. So they got the torque back up. With cam bumped to 96hp And 122 torque. Torque is 120 by 2700 rpm. I like the sound, going to run for awhile and decide if I want to try a different headpipe but happy for now. With torque where it is at I doubt I will be changing. I don't need much more help getting into trouble. Hope this helps. There are some other threads on these if u look around. My Dyno sheet is touring section. Bagger Dyno charts.
