ABS Failure on 2018 RGU
For the past couple of hundred miles, I became aware of a vibration when applying front brakes from cruising speeds around 70 mph, such as slowing to take an offramp from the highway. I figured it was related to warped rotors, or maybe a front pad problem, so I spent a couple of hours looking over and cleaning my front brakes. I couldn't see anything out of the ordinary, and the vibration continued. I made an appointment with the dealer shop and took the bike in two days ago.
The tech said he got codes from the ABS when he hooked it up to the brain. I had never seen an error light at any time, and told him that. The service writer told me they'd had another bike in a few days ago with similar problem, but that bike was showing the error lamp. Mine never did. Late in the day, the shop called me and said they need to replace the ABS ECU, and have the part on order. Bike is still in the shop awaiting this part. Looking in my manual, it appears the ABS ECU is integrated with the ABS module. My manual says the two units are not serviceable separately. So looks like I'm getting a new ABS module. Apparently, my ABS was activating during normal braking. I felt the vibration only at higher speeds. Once speeds dropped below around 50 mph, I could no longer feel the vibration. I figured it was worth mentioning here, since it would be easy to ignore this vibration. Otherwise, the brakes worked normally. |
Originally Posted by KrustyKush
(Post 17952555)
Very interesting. That is the first time I have ever heard of this issue. Was the other bike they had issues with also a 2018?
Good luck and hope they get it fixed right and quickly. |
Originally Posted by Cosmic Razorback
(Post 17953101)
Darn good thing my bike is a 17!!! :icon_couchhide:
God to here your on top of things and your getting a new ABS ECU installed let us know how it works out for ya.
Originally Posted by PDB17UltraRG
(Post 17975554)
© 2024 MH Sub I, LLC dba Internet Brands
