M8 Crank run out.
Campy Roadie (01-16-2019)
Allowable oil consumption is another high allowable limit that really is ridiculous.
We live in a mediocre world ladies and gentlemen.
I agree about general mediocrity.
But, there are literally hundreds of thousands of these engines motoring over the highways of the world. Very, very few of them are having failures of any kind. Let alone the kind of problems (oil pumps, compensators) being ruminated about here.
This suggests to me that spot measurements of this and that are relatively unimportant. Now, if we had a failure rate around 99% then we could be talking about something. I've personally seen a tendency in gear heads to get obsessed about some little particular that really is of no practical consequence. The machine is designed to run well in specific conditions, to get us there and back safely. As long as it does this, where is the problem?
I have no idea of the failure rate but it does sound like there is something going on that might be traced back to tolerance stack-up with the sumping issues and pump failures. Goes back to high allowable tolerances with two or more borderline (within limits) parts coming together in the same engine. Presto you have a turd. Since theres a bulletin on the sumping concern there must be a regular enough occurrence to warrant it. Yes im off topic (sort of) but with cranks as true as skipping ropes and pistons going chernobyl roughly for 3 model years now not to mention transfer someone dropped the ball. Makes me think an old shovelhead with an intake manifold leak is still a better engine than an M8.
fishdoktor (02-07-2020)
