M8 Crank run out.
M8 Crank run out.
Started disassembly for cam install on my 17 RGU this morning. Very disappointing to find nearly .005 run out on the crankshaft pinion. Did my 09 twin cam a few years back and thought .0035 was bad. What kind of run out are guys out there finding? Just curious to see if any are spot on like they should be. Thanks, Mike
Campy Roadie (01-16-2019)
.012" means other tolerances have to be loose to allow that much runout and not cause a problem. Crank runout on car engines I build get corrected if they're at .001". I understand the bearing setup isn't babbit but still that leaves a lot of room for improvement. Good ole tractor engine lives on in the 21st century!
.005 is not all that bad is it? My Indy said .006 is the limit, he said a 7 or 8 could start to eat away at the oil pump. Harley spec at .012 is ridiculous, been that high since around 2002 or so. The Harley 3 pc crank has been a sore spot to me since they came out, I think it was around 2000 or 01.
As mentioned above and in earlier posts, all the big twin cranks have been assembled from components, the Twin Cam was press fit vs the Evo being nutted. The M8 is a pressed together crank like the Twin Cam.
