Routing clutch/brake lines on new handlebars
You guys that have installed taller aftermarket handlebars on your Road Glides, how did you route the stock hydraulic lines from behind the gauge cluster out to the handlebars? Did you go out from the sides of the cluster housing and up the bars, under the bars then up? Any pics? The pic here shows the two places I'm referencing.
I installed 14" factory 47s, and i cut two zip ties under the gauge cluster holding hydraulic lines down. that's all i could find to help pull some slack. i have the lines running out of the sides of the gauge cluster (top red circle in my pic above) currently. just curious if this is the best option!
