Transfer Issue
I have a couple kits left if you want one, but you won’t be able to pm me until you have 25 posts. The fat clutch rod has been reported to work by those that have tried it. It is less expensive than my fix and easier to install. If I was having the problem I would go with the clutch rod because of the reasons I just gave you.
Received 14,655 Likes
I haven’t seen any description on why the “fat flat rode” works.
I’m thinking that since the issue is due to a lower pressure developing in the primary, it sucks from the transmission. Maybe some primaries leak a little pressure, and thereby didn’t develop enough vacuum to suck from the transmission. The flat side of the rod allows pressure equalization between the primary and transmission. They make it a bit thicker, because the stock rod does not have enough material thickness to create the needed flat, and it would also weaken it....
But, I could be wrong...I thought I was once...but I was mistaken.
