SiriusXM Signal on Boom GTS
I just added the module to my '19SGS and found that the signal is marginal at best. I have it mounted on the magnetic bracket on the right (throttle) side just above the speaker pod. I noticed on some instructions for an earlier model that the antenna cable connecting to the puck should be run so that it is facing the radio or towards the center of the fairing.
Does it matter which way this antenna is turned? I thought my metal windshield trim may be affecting signal but apparently lots of people have this issue across multiple year models. When I am on the freeway it seems to be ok, but on side streets the signal is spotty. There is nothing directly above me, just along the sides of the street but for some reason the signal drops intermittently. Sirius support suggested doing a signal refresh but I don't see how that would make a difference.
Anyone have XM that works perfect?
I don't have one on my bike but the signal in my wife's Durango and in the Buick I drive drops ALL the time. If there is a tree by it, a power line over head, a hill side. Pretty much anything. I'm not a huge fan of it. Back on the subject....LOL. I don't think it's out of the norm to have intermittent signal loss with XM.
So, I am not used to this. I think I am going to move the antenna to the far front of the magnetic bracket and see if that helps.
Eccool (03-25-2019)
That is not an option, I have a windshield bag and use it frequently. I am going to toy around with location under the fairing first. The day I tried it it was very overcast and from what I have been reading that can be an issue with any GPS. It's not a problem with my Santa Fe but apparently there are other cars that don't like cloud cover too much. I find it strange that not many actually do have an issue, this problem is out there but not in near the numbers I would imagine. So, I'll do what I can and see if I can get it working better under the fairing.
Two things you can do 1) move antenna outside of fairing, 2) Get new upgraded antenna P/N: 76000221A OR B. I think the latest version is 76000221B.
You may be able to use new, upgraded antenna inside fairing and get acceptable reception...I have P/N: 76000221A mounted outside fairing and it is MUCH better than the antenna that comes with the XM kit. Best reception will always be with upgraded antenna mounted outside of the fairing. Good luck!
