Cycle Rama CR480
#101
#102
FWIW, I pulled the inserts on my TTS tuned 124” build with the FM Outlaws and had to put them right back on cause the bike ran like crap, sputtered and back fired. I think the tuning on my setup is spot on, and the increase in airflow really affected it in a yuuuge way!
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
#103
We've noted this effect many times, these motors are very sensitive to exhaust especially when you change out the stock cam. When you have a baffle or muffler core that is larger than necessary you lose velocity and this causes issues with low RPM performance & response, having an exhaust system that functions properly with your combination is key.
If this was reversed how would it affect the tune, by reversed I mean if the bike was dyno tuned with open mufflers (2.5 baffle)and you then put a more restrictive muffler on like your street outlaw, would it need a retune or would the ecm compensate?
#104
#105
If you are changing the flow characteristics considerably its going to greatly affect the tuning, this is also going to be proportional (i.e exhaust tuning is affected to a lesser degree on a stock engine than an engine with aftermarket cams, big bore, etc..) Also note the ECM can only adjust in closed loop, this does not include any of the higher load, upper RPM areas or at wide open throttle.
porkster (07-22-2019)
#106
#108
#109
#110
S&S 124" kit 11:1 comp.
Fuel Moto/ Ward ported S.E. throttle body with 5.5 S.E. injectors
Fuel Moto/ Ward ported Level A cylinder heads.
Fullsac header
Fuel Moto Outlaw muffs.
Woods 408 cam and Woods Alpha lifters.
H.D. latest oil pump with new backing plate to cure the sumping issue (which so far it has).
AIM SDR clutch with S.E. 1275nm springs (stock 9 plate clutch plates)
TTS tuner
