high flow exhaust vs street cannons
Trading a 16 Limited for a 19 limited in july. My question is, is there a noticeable bump in torque/horsepower between the high flow exhaust with the street cannons vs just the slips on street cannons. I'll also be adding a high flow air cleaner and tuner. Is it with the extra 1K?
I considered this, but decided no, not worth it for a simple Stage 1..I had mine dyno tuned with SEPST which cost about 1/3 of the Hi Flow Exhaust exhaust upgrade and got good results...there are some here that have done what you're considering and are happy with the results, even going the extra mile getting the SE ATM with WB 02s which the Hi Flo exhaust is tapped for...but then you're talking around $2000 spent on just an EPA compliant Stage 1, which obviously the biggest benefit is maintaining your warranty. and if you do want to go that route be sure to do it within 60 gays of purchase. Another better option in my mind would be do the SE Stage II Torque cam instead. And if the warranty doesn't matter there's a ton of knowledgeable folks with experience with the aftermarket performance upgrades on this board that can steer you correctly in that direction. Congrats and good luck!
that's a good question..I installed my AF and mufflers but it was after 60 days...ask the service or finance guy at dealership as they are the most knowledgeable about warranty stuff I suspect, maybe check your Owners Manual...but honestly if you're buying a new bike just tell them you want the Stage 1 installed as part of the deal, and even try having them throw in a 1K service..bet they agree as service/labor costs are one of the easiest things to finagle
You can install any Harley part and / or perform any and all maintenance and still be in warranty, just keep receipts. I installed the complete high flow exhaust system, intake and tuned it with pro street tuner in one day. I am really happy with the system. It not only gets the catalytic converters out of the Headers and into the slip ons where they belong, but also provides up to 10% HP increase across the entire range and sounds great!. The high flow headers also have a bung hole that will accept the Smart tune pro wideband O2 sensors so if you are considering that auto tuner it will save big bucks on boring out and welding bung holes on the stock headers.
It really is the best system regardless of what stage you end up with, but it does cost 2K for the system. Like they say, you get what you pay for.
