PIN Change
Received 19,515 Likes
Here you go from the owners manual, should show in the OD window:
1 Select a 5-digit (1 thru 9) PIN and record on the wallet card from Owner's Manual.
2 With an assigned fob present, turn the OFF/RUN switch to RUN.
3 Cycle the OFF/RUN switch twice: OFF - RUN - OFF - RUN.
4 Press left turn signal switch 2 times.
ENTER PIN scrolls through the odometer window.
5 Press right turn signal switch 1 time and release.Turn signals will flash 3 times.
Current PIN will appear in odometer. The first digit will be flashing.
6 Enter first digit of new PIN by pressing and releasing the left turn signal switch until the selected digit appears.
7 Press right turn signal switch 1 time and release.
The new digit will replace the current in odometer window.
8 Enter second digit of selected PIN by pressing and releasing the left turn signal switch until the selected digit is present.
9 Press right turn signal switch 1 time and release.
10 Enter third digit of the selected PIN by pressing and releasing the left turn signal switch until the selected digit is present.
11 Press right turn switch 1 time and release.
12 Enter fourth digit of new PIN by pressing and releasing the left turn signal switch until the selected digit is present.
13 Press right turn switch 1 time and release.
14 Enter fifth digit of the new PIN by pressing and releasing the left turn signal switch until the selected digit is present.
15 Press right turn switch 1 time and release.
16 Push the OFF/RUN switch to OFF.
Pushing the OFF/RUN switch to OFF stores the new PIN in the module.
Originally Posted by coolbreeze3646
Are you using the ignition switch for the Off On procedure? Do not use the engine kill switch on the hand grip.
