Amsoil primary/transmission fluids
For those of you who use the stuff, can you use one of them for both or do you need to use them separately? Example: use the primary fluid in both or primary in the primary and transmission in the transmission.
I ask because, as i知 sure most of you know, the Harley fluid (either the forumula + or the synthetic version of it) can be used in either cavity.
I have used their products before (both Amsoil and Harley), but I used the 20w-50 in my engine and transmission/primary on my 06 sportster. I知 thinking this time around I should use something that is designed for the particular application (primary/transmission).
Michael Haz (04-02-2019)
You make a good point. I didn稚 really understand why they (Amsoil) made 2 separate products when other manufacturers make one product that works for both.
KISS principle. today fluid manufacturers make a flavor for everything for marketing / revenue generation. Look at Mobil 1 website just under engine oil, my Lord there's a dizzying array of choices. I remember when Vodka was just Vodka and now they make everything from Peach Mango to Pomegranate Jalapeno! I just used what the manufacturer recommends for my auto and bike because it does the job
The following 3 users liked this post by SWThomas:
Vision (03-30-2019)
I realize, of course, there is more than one way to do things like this. I致e been reading some fairly positive things about the Harley synthetic primary/transmission fluid.
I believe it's better to use specific lubes for each different application...but now we have a common issue with the M8s Touring bikes (hydraulic clutch) transferring between the transmission and primary. The AMSOIL transmission lube isn't wet-clutch compatible, so herein lies the issue, should the fluid transfer from the transmission to the primary the result could become a slipping clutch too. This isn't an AMSOIL lube problem though, it is a HD MoCo problem. So since I currently have the specific AMSOIL lubes in the trans and primary I have to be vigilant in my oil level checks so that I catch any transferring issue early. Fingers crossed so far. This would be the case with many specific lubes by other manufactures too. So, the next oil change I do will be AMSOIL Vtwin 20W-50 in all three holes. This is what I recommend to all new HD customers as the first choice and AMSOIL recommends the same as well. The first choice in the above link shows this. I still prefer a specific lube for each application, but this transferring issue with the Touring M8s throws a wrench in the gears to this train of thought. Keep in mind that almost all metric bikes use the same lube in the same sump for the engine and transmission, like the Yamaha Roadstars and Stratoliners, Honda Goldwings, etc. They don't have transmissions blow up due to using a non-specific oil.
Hope this helps, Dutchy
The following 3 users liked this post by Dutchy3051:
