M8 Breather Bypass
M8 Breather Bypass
What are you guys doing for breather bypasses on your M8's? Just looking for different ideas before I do mine. I was just going to add a piece of hose off of the tee in the center and run it down to a hole I will drill in the bottom of the stock air filter housing and attach it to a can or a breather. Seems simple enough.
I did this but I ran the hose from the back plate out the bottom of the frame with no catch can. I've never seen an oil spot on the garage floor. I used a PTC bulk head connection on my air cleaner backplate.
any discharge/residue mess on the bike, or does it just evaporate into the atmosphere, which is the best case scenario obviously and if not noticeable on the bike anywhere kind of indicates it's pretty minimal and largely an insignificant amount..I like your idea if that's the case cuz' I'd be too lazy to want to clean out a catch can, but wouldn't care for it getting on the bike, tires, brakes, etc.
mjwebb (04-01-2019)
hose from breather bolts
I did a bypass on my last bike and really didn’t see any benefit in doing so. Until someone can point to a rash of engine problems, or any other issues attributed to the stock breather system, I’m just gonna leave it the way it is. I run my oil at the midway point on the dipstick and don’t have any oil dripping.
