change cam on SE stage 3
Just wondering if any of you mechanics know if theres a different cam for stage 3 that would produce better torque at lower rpm? Runs great but don't need power after I am past the car. Also would a change like that void ESP warranty? This is on 2017 road king. Factory warranty is expired.
Wmoor004 (04-06-2019)
There are better options but if your esp is through HD changing the cam to an aftermarket would impact your warranty. You could go to the HD stage 2 torque cam in the stage 3 and run the HD auto tuner. I was thinking of going Stage 4 with the stage 2 cam in my ‘17 before I traded. Dealer called HD and they said as long as everything was still HD parts and epa compliant it would not impact my HD esp.
Good Luck.
Good Luck.
wheelock4 (04-06-2019)
Is there a point of even doing the Stage 3 if you want to use an aftermarket cam and tuner?
Asking b/c im at a cross roads.
I'm currently looking to do a Stage 2 Aftermarket Cam most likely Redshift RS468 with PV Tune and then Dyno Tuned.
I already have a Stage 1 consisting of Rinehart 4" slip ons with Slimline Duals , SE Ventilator and Powervision tune.. Its a 2017 RKS and warranty is pretty much up regardless. So if I did a Stage 3 I would still go aftermarket tune and Cam...
I guess my real question is Is there enough gain there to warrant the extra cost? and would you go with the Harley Stage 3 set up ? Seems with all the Sumping issues a stage 2 aftermarket cam would be the safer bet??
I was primarily going with the Stage 2 Redshift cam for the additional lope and some low end torque and it would be a plus for rides when my wife is riding with me.
It may be all I need.
If your stage 111 was done right it includes,pipes,breather,high lift cams with increased clearance dual valve springs,high compression pistons,114 barrels and a tuner.If this is not significantly and aggressively powerful in H P and torque,across the 1800 to 5500 rev band something is missing? No way in hell could a stage 11 cam give more of anything by itself.
wheelock4 (04-08-2019)
