After market air filter woe
Okay changed my stock 114 air filter out to a high flow one that claimed I can use my stock cover, well yes and no, the 114 air filter is really 4 pieces, the backing plate, the steel cover, the screen mesh in front and the bottom plastic piece that when combined with the 3 pieces becomes one minus the backing plate, okay, I changed it out, but you can only use the steel cover minus the screen mesh and bottom plastic piece as there is no way to hold the 3 together, thus looking at the side it's ok, but when looking at it from the front it looks like Bubba got in a bar room brawl and lost his front teeth, not looking so good. Anyone have a way to hold the front mesh back in place on the front? Thanks.
Which air cleaner are you installing? There is a black bracket on the throttle body that most likely you need to remove. It has a wire zip tied to it you will need to take off. I just installed a Stage one air cleaner and i had to remove that bracket.
If you installed an air cleaner that came with it own backing plate like the Arlen Ness Big Sucker or the Screamin' Eagle Wedge, then no you won't be able to run the anything but the stock metal cover. If you want it to look stock and want more flow then you need the K&N 1717 air filter element that only replaces the stock element without changing anything else. You could probably buy the same screen mesh at the hardware store and fabricate your own piece to fit.
