Question Low fuel odometer symbol (LF) meaning
I guess that LF function was turned off when I bought my bike because I've never seen it. A week or so ago I pushed my luck on fuel mileage. I had about 170 miles on the tank when the light came on. I went another 40 miles. When I filled up it held right around 5.6 gallons. So to reiterate what was already said, harley fuel gauges suck... I mean very conservative.... Its always best to figure out your MPG, set your trip, and track it that way especially on a road trip. If I fill up when the light comes on, it usually holds around 4.6 gallons.
It is a pretty good replacement for the petcock that you had to find with your left hand and move to "Reserve" after your bike ran out of gas in traffic while you were in a turn. And wait the eternity for the motor to start running again.
Back in the day before fuel gauges, when the only way you "knew for sure" how much gas was left in your tank was when it ran out.
talkingrock (04-27-2019)
This maybe a dumb question, when I’m low on fuel and the (R) symbol shows decreasing low miles, I also have a screen that displays the LF with a high number that increases usually around 200 and slowly increasing. I figure it means low fuel. What actually is this this and it’s meaning.
While the gauges can be hit and miss the countdown on the miles till empty and fuel light have always been very accurate on all my Harley's. I have run them down almost to bone dry on lots of occasions when I get snobby on what gas is available. I will take the light and fuel range over a carb, petcock and a reserve any day.
911teo
Electrical/Lighting/Alarm
09-08-2018 03:38 AM
