header, slip ons, intake and tune now throwing codes
Installed a de-catted factory head pipe, tab zombie slip ons, a trask ac along with a PV 2 tuner with a tune mapping from Fuel moto on my 17 RKS. I am now throwing 4 codes
p0031 Front Ho2s low/open
p0051 Rear HO2s Low/open
p0134 Front Oxygen sensor High /open
p0154 rear Oxygen sensor High /open
Is this because the cats were removed and tune didn't account for them or from what I am reading a potential exhaust leak will throw these codes? Is it weird to have both the front and rear codes with an exhaust leak. Will an auto tune help? Bike running good but has a slight pop sometimes on deceleration butI also didnt want to get on it too hard with the codes.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Make sure they are installed in the correct pipe front/rear (rear cylinder O2 has the black plug, front cylinder O2 has the gray plug), also make sure you have flashed the proper map for your application for use with the factory O2 sensors and it is not a Target Tune enabled map for use with the Dynojet wideband sensor kit.
BezerkoBob
04-09-2009 09:37 AM
