Name that noise
Name that noise
2017 with 19K+ miles. No sumping, no transfer, really no issues until as of late. This noise started awhile back, figured it was lifters. Figured since I was going to replace the lifters, why not put in a cam, SE adjustable PRs, latest pump and backing plate. I had a thread about the new setup making noise, got that solved by filling the lifters and that was fine. Now this cold start noise is back. Swapped out lifters yesterday thinking maybe I got a bad one, still have the noise, maybe not rattling for a long, but still there. PR adjustment deeper into the lifters makes no difference. And no, I don't think it's anything loose on the outside of the motor. The noise seems to be coming from the front top rocker area. Cam chest side down low is normal amounts of noise.
I'm beginning to wonder if a rocker base or shaft is starting to go? Or the rocker mounting bolts? Only does it on the first start of the day, subsequent starts sound normal. Valve train seems a bit louder with the 465c cam, reminds me of my twin cam. Hauls ***, no indication of any performance issues.
So anyway, if any of you have had rocker problems could chime in your thoughts, I'd appreciate it. In 4 weeks I leave on a 2500 mile trip. Two years ago my twin cam left me stranded in BFE for 4 hours waiting for a flat bed tow truck, so I'm quite spooked with this noise. I don't mind stuff breaking, I just don't want to be out in BFE when it happens. I'd rather not open the rocker boxes, but I'm thinking I should to do an inspection...
exactly was what I was going to say but figured I'd be admonished. lol..mine make that noise initially on cold start up and goes away in a minute..I can press my boot against the left side shield and it will stop
Seems like you have a misfire at the same time. My bet is that you have an arcing spark plug wire under the tank. The '17's are known for this. The '18's and up have an additional couple of clips to keep the plug wires from rubbing on the tank. I got some to put on mine the next time I have the tank off.
Thanks guys, I'll go over the heat shields but I believe they're tight but who knows. I know about how the floorboards can be loose unless really cranked, I'll check that too.
@Strych9, no misfire, that's the 465c cam combined with the fact that I bumped down the cold idle as a test to see how that may have affected things. The 465c is really bumpy at idle. Setting the idle up to near 1000 takes care of that. But I'll have a look at the wires anyway, I'm aware of that issue too.
