Transmission Primary Lube Migration
#91
#92
#93
The Svc Manager told me when my bike was in for migration and they installed the previous version. Meantime MOCO provided the above vent kit and what the Svc Mgr called an updated deflector which he called a wiper gasket. We will see. I am leaving on a 5K+ trip on Monday. Good luck.
The following 2 users liked this post by mjwebb:
BrandonSmith (05-16-2019),
flash1034 (05-24-2019)
#94
#95
#97
A bit of an update on my migration issue.
I machined my trans side cover and also installed the AIM s/c and corrected all fluid levels. Took the bike on a short 20 mile ride, between rain storms, bike did NOT transfer a drop. Before it would happen instantly, say within 10 miles.
I will continue to monitor fluid levels, but I am HIGHLY confident I have fixed the problem.
Current set up:
1) Machined trans cover.
2) AIM s/c
3) "Fat rod"
4) NO VENT KIT (I machined a passage on the trans cover, my theory is, is that will allow the primary to vent more in line with the HDs original design with the transmission.) Time will tell!
I am also of the opinion that the real "fix" is the machine work on the trans cover. I believe it would work with the stock clutch rod and actuator, although I am unwilling to test this theory merely because I don't have the time to do it. (I am on-call 24/7/365 and my personal time is few and far between.)
My machine work.
Current set up:
2) AIM s/c
3) "Fat rod"
My machine work.
#98
#99
As I posted further up in this thread, the "fat rod" was installed first, but didn't stop transfer. (A UV dye kit was used as well as fluids measured.)
Since the HD dealer can't get me in until June 11th, and they are unclear as to if they can get the Moco to just send the vent kit and install it in a timely manner, I took the issue into my own hands.
With some info I learned on this board as well as HTT and especially Stonecold, I decided on the course of action I have taken.
Also, as stated above, I don't have time to do a complete test of every single possible remedy. I suppose I could pull the "fat rod" and re-install the factory clutch rod to prove a theory since it is an easy swap, but frankly with positive results with what I have done to this point, why bother.
I will continue to monitor my fluid levels, closely. When I get some more miles on the bike I will post in this thread whether or not anything has changed.
#100
Also, sorry as you did state all above in a previous post and missed I it...
