RPM revs up coming to a stop
I have a 2019 sport glide and the RPMs has always revs up to about 1250 (seen 1300 a couple times) when slowing to a stop. Typically around 5mph is when it happens and it occurs for a few seconds before it settles down to just below 1000RPM. The dealer doesn't know what the problem might be. I have the HD stage one, heavy breather and street canons - all installed by the dealer.
Thanks
Thanks
Thanks
Thanks
https://www.hdforums.com/forum/milwa...bullish-t.html
This description makes it seem like the clutch safety switch issue on the left handlebar control module. If so, it seems odd that this might still exist on a 2019 model. The updated parts have been out for a couple of years now, and should be incorporated into the 2019's for sure. Maybe just a failure in the updated part.
My 2017 CVO SG had what I called crazy idea. I am not sure rather or not this is what you are describing. As I was coming to a stop, or feathering the clutch in stop n go traffic, the idea would sometimes jump to 1300 to 1500. Dealer could never repeat as they didn't ride it under the right conditions. So I paid to have them change the clutch switch per other forum member recommendations. It totally fixed the issue. Not saying this is your issue, but I do suggest reading about the clutch switch. Some have had good success with cleaning it using electrical contact cleaner. If you decide to try this, I suggest being careful as some of these cleaners can eat black engine powder coating as well as paint. Cover everything well..
If the clutch is pulled in the bike should start in gear if not the clutch side switch pack is bad, very common problem with the M8's since day one and it will make your idle erratic and can die at stop lights, how I found mine was bad. You can dab a bit of lube on the plunger between the handle and housing. Seems to help a lot of them.
