Performance & Dyno effects between mufflers on Milwaukee-8 engines *Dyno Tests Inside*
#71
WTH, you never hear about Thunderheader or Patriot anymore. Has anyone done any testing with TH on the M8 because since installing mine it's like a brand new bike. I had a complete Rinehart 4.5" exhaust system and it was worthless. It's for sale too in case anyone is interested. Great pipe
That's cuz after listening to them for a few years, you go deaf. You don't hear anything.
#72
Magnaflows vs Jackpots
FM 117 big bore
CR-460 cam
FM 2-1-2 headpipe
FM AC/DC air cleaner
Power Vision tune
#73
#74
Those are hitmans correct? I cant remember if the baffle was any bigger in them over the 4 inch knockouts or not. If it's no worse than that I can live with that all day for the sound difference. I put my stock cvo mufflers back on yesterday just to see if there was a difference, I could not tell any difference other than the awful sound, I dont have the cam in yet though.
#75
I posted this a long time ago and it's on a Twinn Cam bike but it still shows the effect that the exhaust plays in the low-end Tq in these engines.
So my 2014 103 at the time the Dyno was done had Andrews 58 cams, the blue line was with a ceramic coated 2-1-2 head pipe with RC 4" mufflers that had 2.5" baffles. Then we installed a Rush Wrath 2-1 exhaust which also had a 2.5" baffle but remember, your now pushing all the exhaust through that 1 and only baffle. The difference is huge as far as where the Low-end Tq comes on, huge. At 2500 rpm's your looking at 30ft lbs. difference which is going to be noticed.
#77
Going from the SE street cannons to the V&H has been a huge drop in low end torque. The sound now in my opinion is much nicer and yes a bit louder, it sounds more like a typical twin cam bike.
This is the closest performance wise they have come to the Street Cannons, no packing and TTI as pictured. I have 400-500 miles on this combo and I am happy.
18 RGS stage 3, SEPST, smart tune pro with cat
#78
I put the TTI’s in my V&H 450 destroyers. I have tried several different combinations. The inserts in line with exhaust, a 45 degree angle and as pictured, with and without the packing.
#79
#80
You might want to consider this before you go with the 1.75" baffles.
As you can see, the 1.75" baffle came just a little earlier, but by 2500 rpm the 2.0" baffles had caught up. Since you went with the Rineharts, I get the idea you like some sound from your exhaust. I have the 2.0" baffles in a set of standard stock cans on my bike and it isn't much louder that stock. The 2.25" cores might even be a better choice for you. They will be louder. Again, the curve will move slightly to the right, but it probably won't be noticeable with the butt dyno. No matter what you decide, get the Techmats. They will keep the mufflers from having a tinny sound.
Now I’m rethinking going with 2” now.
The Rineharts with 2.5” baffles and cat in, is still a bit too loud, but sounds awesome, I hope this would be quieter.
