Let us know if your HD primary vent fix has worked or failed
#141
I've still got more than a year left on my warranty. I'll have ask the service manager if they will install one on mine just in case. As of now my stick has stayed on the full mark.
I tried to see if I could make it transfer by running a full tank of gas in the 3000+ range. No transfer but I've read a few post in this thread or another thread about the same subject and some of those guys stated that their bikes started transferring trans fluid after they had some miles on the bike.
#142
#143
#144
ESP coverage
and there's plenty others, like myself, where the transfer subsided to about nil after racking up the miles over the years..in my case engine oil consumption has gotten less and less over the years and miles as well to where it's just not a problem..go figure...I have 4 years left on my ESP and I have no need or reason to pursue the vent..don't introduce change to try and fix what's not broken is where I'm at anyway
#145
I just had a15000 mike service and had some transfer, (2017 Ultra Limited) and was told that it is out of warranty and that my ESP doesn’t cover it. (The vent). Problem was logged with the MoCo, and will monitor future transfer per MoCo. I’ll argue that issue when it needs to be fixed.
#146
#147
#149
#150
I have a few questions I hope someone can answer. I am coming up on my 5k service and I have yet to have any transfer issue. Should I bother installing the vent myself while I'm doing this service or let it go since I have not had an issue and still have a year left on my warranty?
Also, If I do not install the vent, do I run any greater risk of damage if I use Red Line V-Twin Transmission Oil with Shockproof and eventually do have the transfer issue? The reason I ask is I know the Red Line has a suspension additive and I'm wondering if that would negatively impact the primary if I do get the transfer. I've had good success with this oil in my Dyna so I want to keep using it.
I'm doing the 5k myself but had the dealer do the 1k.
