M8 Road Glide Ambient Air Sensor stopped working
The left switch cluster is a known problem, had mine replaced under warranty about 6 mo ago, not sure if they'll replace under goodwill if your warranty is up or not. If not it's a pricey switch, I think it's actually cheaper to replace both with the lighted switches, with the canbus system you can't fix the switches. The radio reflash changes some of the radio switch functions, they can be changed back, not sure exactly how it's done, should be in the radio manual.
So the AAT reading "--" is the only current issue.
So my cruise isn't working after all, guess the left control is kaput I wonder if me getting caught in a massive downpour a few weeks ago caused this. So I went ahead and ordered a set of lighted switch packs since they were marginally more than just the left. (Though I've no desire for the PTT switch on the right pack, is that switch removable?)
Anyway... fingers crossed the replacement switch pack fixes the cruise control woes and I don't have bigger problems developing.
Well hells bells... being frustrated with my Cruise and Air Temp not working... I went out and pulled my old fuel pak 3 I started out with the bike with and flashed my original map and sure enough both air temp and cruise were functional again. Then turned around and flashed the PowerVision map back and sure enough they are still working.... What the hell????
Cancelled my Switch Pack order and I'm 100% again.....
The following 2 users liked this post by 3dognate:
2017M8 (06-17-2019),
SomeOld Biker (06-16-2019)
