M8 burned oil and loss of power what does harley do in 2019
Hi took delivery of 2019 trike a few weeks ago
road around town per break in instruction, last week road 75 miles on freeway st 60
noticed som loss of power at end of ride then smelled burned oil put in garage and checked oil - down a quart and very strong smell of burned oil
transmission no oil on dipstick....put pipe cleaner down trans dipstick hole. ..found fluid 1 1/2 inch below dipstick
called dealer for pickup
waiting for tear down
what is HD doing with seized engines?
Eccool (06-03-2019)
Campy Roadie (06-03-2019)
As I said....I have no real knowledge here, but I will be watching this case with interest to see what the ultimate cause is determined to be and what remedy will be implemented.
Am I missing something here?
I claim no special knowledge about sumping. And I have figured out that there are few (if any) folks that can explain exactly why it happens and therefore can't predict when it will happen. But from all the anecdotal experiences with sumping that are contained in this forum, it just seems inconceivable to me that whatever happened to the OP was sumping. To my knowledge, no one has described a riding history as short and mundane as the OP has described and then experienced sumping.
You haven’t installed any stage kits have you ? So it’s a stocker that has about 100 miles on it.
Wiz 🍻
All it takes is a bike that is susceptible to sumping to reach full temp and rpms that overwhelm the oil pump’s ability to remove oil from the crankcase faster then its arriving. Crankcase fills And the crank starts sloshing through the excess oil, generating heat. Do it long enough and lots of bad things can happen to the engine.
75 miles is plenty of time for the engine to sump bad enough to lose power. I experienced it once in less than 50 miles.
Classic sumping symptons. Loss of power. Smell of burning oil. Oil level extremely low on dipstick. Guaranteed its sumping.
And based on the history of this issue, your CVOs would definitely have fit into a "susceptible" category. The confusing (and disturbing)thing with the OP is that this is a stock unmodified 2019 M8 and statistically there should have been a less that 1% chance of occurring. Just proves how difficult this phenomena is to deal with. P.S. what are the odds of sumping and transfer happening simultaneously in the first month of ownership? Yeah....I'm a little skeptical.
Where did you get the “1%” figure from. Is that just your personal “SWAG” or a sourced data point?
