T-Max horrible MPGs HELP!!! 19' ultra SE462
Hey guys, My 19' ultra is in need of what I think is timing adjustments that I am not 100% comfortable just messing with w/o asking someone first. setup is: Arlen Ness Big sucker stage1, SE462 power cam, V&H pro Pipe, Tmax tuner(base map is stock 114' with d&d 2:1).
Im wondering if someone has a good base map for the timing side I could try, or maybe look at what I have currently and tell me what to adjust. I watched alot of cyclesoultion videos from a few years back and kinda mimiced the AFR to RPM tables he had. I know the timing needs help i just dont know how to and where to start. Aside from MPG the bike runs great, but stock I would get around 38-42 hwy now im in the 28-34 range at the same speeds.
Thanks in advance to anyone wanting to share their knowledge.
Jake
Jake
Jake
Jake
The Tmax site has a bunch of base maps available, just go to the M8 maps and look for one with a cam, last time i was on there they had a few 114's with HD cams loaded up.
The following 2 users liked this post by sgs18:
PFWiz (06-10-2019),
Smoked~black16v (06-10-2019)
I updated and went with the 114" stock cam HiFlo Cleaner and D&D 2;1. they dont have anything that im seeing for the M8 and SE cams. Ill be sending them a file off my tuner and see what they think. I had set my cruise range afr/rpm to the 14.2 (between 1800-3500 iirc) range but a friend told me i should bring those down a little as 14.2 is a little lean being air cooled. i do mostly freeway/ 40+ mph riding but ill lower to like 13.9 and hopefully TH can get me a better timing map to go with.
sgs18 (06-10-2019)
Jake
Jake
