Would you trust a Thundermax to properly auto-tune a built 124?
Please update us on the before and after results with the Fuelmoto Thundermax Map. I have used Thundermax on a couple of "built" 107 Twin Cams in the past, and always felt like I was leaving something on the table, but never never had an exact match starting map like FM is providing to you.
Vision (06-27-2019)
So far the map is working out well, it did get rid of some decel pop I had right around 3000 RPM’s. The bike feel to be giving me more down low, but without Dyno results, it’s hard to tell. I really appreciate FM for sending me the Map. The bike runs great. However, with the new technology in the Delphi ECMs and the flash units like PowerVision, that work with them, I’m wondering if I’m leaving something on the table as well. On the fence of pulling the T-Max, getting and additional license for my PowerVision and having a reputable Tuner do his thing. Thoughts from you guys would be appreciated!
IMO if you go from a Tmax to a Power Vision you just threw away all the benefits you had, you're going backwards.
Vision (06-27-2019)
Doesn’t require costly Dyno tune. It dynamically tunes as you go.
The ease of making slight adjustment (if you know what you’re doing)
Default enabling of Oil Cooling fan vs requiring dealership flash
Nothing written to stock ECM in case I need to swap ECMs for warranty purposes
Blinking Check Engine Light when engine temp exceeds a set warning point.
Things I would gain with stock ECM and flash:
Knock sensor
Possible better performance due to actual Dyno tune including more accurate timing settings leaving nothing on the table performance wise.
Better starts for Big Bore engines in cold weather due to some quirkiness with TMAX Auto Compression release settings
Above is just my understanding. Please add to benefits or disadvantages of both as you see it.
If you want a dyno tune just take it down to Zippers, there in Elkridge, MD, there the experts on Tmax. I guess my opinion on dyno tunes is if it's running well, ie smooth & no hiccups, are you really going to feel that extra couple of HP? The dilemma then is to find a tuner that is good enough to actually find that extra power & still have a smooth running bike, those shops are few & far between.
Having had the Thundermax on 2 built 107s and now a 124 with PV tuned by Fuelmoto, I would never consider going back to a Thundermax. Of course this assumes you have a good tuner available. I trailered my 2019 Road King 600mi to FM in Wisconsin to have the 124 kit installed and dyno tuned and it was worth every penny. If you have a good tuner available or within trailer distance, it's a no brainer, go with PV. If no good tuner is available then settle for Tmax.
