Stage 1, Decat and Warranty
Guys...I traded my Ultra Limited on a Tri Glide Ultra and the heat on the right side is much worse on the trike. I would like to to do a Stage 1 inside of 60 days so those parts can be rolled into the warranty. I would also like to decat the header AND retain the warranty. The service guy at the HD shop said 1) decatting the header would for sure void the warranty and 2) the HD tuner would not be capable of properly tuning the bike without the cat. I doubt #2.
So here's the question. If I decat the header by drilling it out as not to leave any external evidence and take the bike in for a Stage 1, what can I expect?
Is there a way they can tell that it has been decatted, other than looking inside the pipe?
Will decatting alone change the tune enough to require a visit to the tuner?
A really sharp tuning guy might be able to tell, but I don't think we need to worry about that.
Thanks
Thanks
Thanks
Thanks
I think a good HD tech or anyone familiar with M8 engine could tell when one has been decatted. Little bit different sound at the very least.
SO yes. Cool flow fan for the heat and retain your warranty if you're wanting too. I've also heard wrapping headers have decreased the heat noticeably for some.
Does the fan make that much difference? The heat is brutal. I would think that the heat from the cat would cause more issues than is resolves.
Lets say I have the dealer do a Stage 1 and leave the cat. If I later decide to remove the cat, will the bike need to be re-tuned?
I assume you'd be using the SEST tuner. I would think you can just use the standard canned tune map for stage 1, then run a few smart tunes and it would be fine. If you're talking a true dyno tune.....I dont think theres enough benefit to justify the 500 bucks for a stage 1. Just install the stage 1 map from the tuner files and you're good to go.
Also cant comment on the fan as I dont have one. Some here that have them say they work pretty well.
Received 5,193 Likes
I thought about wrapping the headers then putting the chrome heat shields over the wrap. I've heard that wrapping the cat is a no-no. I modded all of my previous bikes right out of the gate and never had to use the warranty, but I thought I'd like to keep the warranty intact on this one. I must be getting old.
What's odd is that when I had a Stage 1 done on a '15 SG a few years back, the dealer offered to decat the header for $50. Something must have changed between then and now.
and I do like my cool fan it helps for sure. everyone repeats the "its limited by the EPA" line, but so far no one has been able to tell me what they really mean buy that, I mean they do not want any unburnt fuel coming out, IMO I don't either that's wasted fuel and not efficient at all, how that means less performance I'm not really sure of.
