Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Milwaukee Eight (M8) (https://www.hdforums.com/forum/milwaukee-eight-m8-198/)
-   -   My 2020 RGL is showing three codes . I can't clear . (https://www.hdforums.com/forum/milwaukee-eight-m8/1367091-my-2020-rgl-is-showing-three-codes-i-cant-clear.html)
pfbmgd Apr 18, 2021 06:23 PM
I just had the dealer put on new rubber . I took the bike for about 45 min ride . This morning I washed the bike and went out to fuel it . The check engine light went on . It shows the following codes b 135c - b 1342c - PO333c . I tried clearing them but they keep coming back . Is the bike safe to ride to the dealer 7 miles away ?
mjwebb Apr 18, 2021 06:28 PM
Originally Posted by pfbmgd (Post 19873846)
I just had the dealer put on new rubber . I took the bike for about 45 min ride . This morning I washed and went out to fuel it . The check engine light went on . It shows the following codes b 135c - b 1342c - PO333c . I tried clearing them but they keep coming back . Is the bike safe to ride to the dealer 7 miles away ?
just tell the dealer and make them 'deal' with it
dave the welder Apr 18, 2021 06:33 PM
What in the actual hell could they have done to throw codes, Installing tires? I'd be giving them a call.
mjwebb Apr 18, 2021 06:44 PM
I know right!
https://cimg1.ibsrv.net/gimg/www.hdf...ed673002f6.jpg
GlidingJoe Apr 18, 2021 07:05 PM
Two of those codes are for your rear speakers. Did they plug everything back in? The P code I can't find
pgreer Apr 18, 2021 07:28 PM
P0333 without the c is a Knock sensor rear circuit high code. The only one that matters much is the knock sensor code.
As mentioned above, contact the dealer and ask them about riding it to them. And you could check connectors for these components, but if it's under warranty, I'd let the dealer look at it since they just had it in the shop. The speaker connectors are easy to access, but they had the saddlebags off to replace the rear tire.
Paul
NODYNA Apr 18, 2021 09:35 PM
If you are not using a top tier gas, google it, and 91 or 93 octane start. Don't pay 25+ and cheap out on the gas.
pfbmgd Apr 18, 2021 09:35 PM
I'm going to check all connections tomorrow .
pfbmgd Apr 19, 2021 07:49 AM
Always 91 octane no ethanol .
pfbmgd Apr 19, 2021 05:20 PM
Dealership is swamped .Can't get appointment for two weeks . I cleared the codes . Took the bike for a ride . They came back .
© 2026 MH Sub I, LLC dba Internet Brands
