Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Milwaukee Eight (M8) (https://www.hdforums.com/forum/milwaukee-eight-m8-198/)
-   -   We've started the 300 hp street fxdr build! (https://www.hdforums.com/forum/milwaukee-eight-m8/1370345-weve-started-the-300-hp-street-fxdr-build.html)
TTS Performance May 17, 2021 03:32 PM
At last we have all the parts to start this build. Many will say this is crazy. I built my customer a TTS Inferno supercharged bike back in 2019. It ran just over 200 whp and 200 ft'lb of torque. With a Zippers 468 cam, SE 117 piston kit, D & D 2/1 exhaust. TTS Billet clutch basket, and compensator ramp. Trued and welded stock crank and rods. Stock oil pump. It ran faultlessly for the whole season, not a high miler but 3000+ miles. He rides the bike but doesn't race it. He heard of a guy in Australia running a TTS supercharger on a 128, running 300 Hp. So he wants something similar. Personally I was pleasantly surprised that the bike ran so well and without issues and made just as much hp when it came back as it did when first built. Awesome!
Before we pulled the motor out I thought I would throw some of the changes I had planned to get him the 300 hp from the knowledge I had gained running my Breakout dragbike. This was to fit the SE 64mm Tb, the same intercooler but with bigger bore pipes and a bigger plenum chamber. The result was 270 whp, I posted the results here late last year.
So now we have the new build. This is more about strength than HP. We had seen the 270 whp so to get to 300 a big valve head and maybe a wilder cam, and reduced compression as its on pump gas.
I chose an S & S crank and rods and additionally welded the big end journal, S & S oil pump, a new set of 117 pistons and gasflowing the heads and fitting 1mm o/s valves I had great success running copper O rings to seal the head gaskets in conjunction with Cometic head gaskets. 1.5 mm base gaskets to lower the compression.
What was good to see was that on glaze busting the barrels to bed in the new rings I found the bore was in perfect condition with no distortion or wear on the thrust faces. Good job Harley! I was really impressed by the quality of the Mahle SE 117 pistons, we don't need to go big and have wafer thin sleeves in the barrels, why slog huge pistons creating all the crankcase pressure problems caused buy them. The lovely thing about going supercharged is the engine has an easier time than stock when your not asking for power, lower compression pistons, not huge high comp pistons that are giving the motor a hard time all the time, No huge high lift cams and heavy valves springs. The superb Rotrex design means off load the supercharger takes very little power to turn it, and through its 10:1 step up gearbox and Planetary roller gearbox it can spin to 120,000 rpm with no noise and fantastic power gains from idle.
Below are photo's of the crank, O ringed barrels, piston machining to clear the small end of the conrods.
I am more than happy to hear any comments.
https://cimg1.ibsrv.net/gimg/www.hdf...ef295d3d7c.jpg
https://cimg6.ibsrv.net/gimg/www.hdf...43ab1aa340.jpg
https://cimg3.ibsrv.net/gimg/www.hdf...a79c16e64b.jpg
https://cimg5.ibsrv.net/gimg/www.hdf...f60a3bb099.jpg
https://cimg5.ibsrv.net/gimg/www.hdf...0492a0c366.jpg
https://cimg8.ibsrv.net/gimg/www.hdf...fde0998fe1.jpg
https://cimg9.ibsrv.net/gimg/www.hdf...cd828b3298.jpg
https://cimg2.ibsrv.net/gimg/www.hdf...42cdaca86c.jpg
Cosmic Razorback May 17, 2021 09:29 PM
Exciting stuff!
Agoober May 18, 2021 12:32 AM
Great stuff , the RS468 would of held power back at revs but the left side grunt where a centrifugal style blower is not at it's best would of been a bonus with that cam I'd say.
Keep us informed man.
dajogejr May 18, 2021 05:19 AM
Very cool build.
Question. Why S&S Oil pump with such great results from the stocker in the initial build and that build done up a little more?
Benefit to the S&S design in your opinion?
TTS Performance May 18, 2021 11:13 AM
With this build we will generate a lot of heat so we are going to run a big oil cooler. So an S&S pump having bigger rotors will help with the flow.
© 2026 MH Sub I, LLC dba Internet Brands
