Tuning a stock bike
i wish that I knew the answer to your question. When I had my 103, I was told that a tuner wasn’t necessary with either exhaust, or air cleaner; but was necessary when both were used. I have read that some, believe the same info about twin cooled. I don’t know, but like you, I’ll be watching for answers from those “know” from experience.
pappy42 (06-19-2022)
I say go for it. I removed my stock exhaust, full Cobra. Headpipe and Neighbor Haters...did a tune with the SE tuner and its more responsive on the throttle. I also run the SE ventilator air cleaner. I did gain a few MPG's...but no bump in power thats remarkable if at all.
Stock 17 you say? Well most would recommend that you change the oil pump to the newest design from HD as soon as you can. While doing that you may as well upgrade the air/cam/pushrods/lifters/tune into a stage II as the job to change out the oil pump involves handling most of these parts. You’ve got no warranty so aftermarket will give you the most options.
What I did…2018 Ultra LTD Anniversary Stage II
Street Cannons, HD 8 Lobe, K&N,
Fuelmoto Cam kit WM8-22X, S&S Cuffs,
PV Tune.
PV Tune.
Max Headflow (06-22-2022)
simply an untrue statement..there is not huge benefit for sure..but overall driveability along with some performance increase that can be felt and appreciated is possible, even with the SEPST..I know this from experience..yes a proper Stage 2 is going to provide the seat of the pants performance increase a Stage 1 can't
The following 5 users liked this post by mjwebb:
Bayou FLHR-M8-128" (06-22-2022),
BrandonSmith (06-22-2022),
Coyotejunki (06-21-2022),
FLTRI17 (06-21-2022),
JohnA. (06-22-2022)
The following 2 users liked this post by beverage:
