WTB: Bt 4180
I'm kinda set on the BT amp due to the dimesions of it. I talked to Tailwind a while back, and he managed to fit a 4180 and a NVX under the fairing. The Arc 600.4 looks too long for my setup. I'd like to be able to just "swap out" my existing amps and install the other amps.
BT= 7x5x1.8
Arc= 8.1x5.4x1.8
I have seen tailwinds pics
The Arc is a little wider but it may still work
The Moto and the NVX will not fit on the tray side by side.
The other option is to drop the 4 channel amp on the tray and side mount the NVX on the clutch side of the radio stack. I have an NVX there as well but it does require the BT bracket aka fairing speaker pod eliminator.
Hell, a PPI 900.4, LLs for Rushmore and the BT brackets might put u in the green!!!!
U do have lots of options if u side mount the NVX.
T.
T.
HawaiiNighttrain
Audio Systems
08-31-2017 04:42 PM
