Mark this thread as Unsold
FS: Rockford Fosgate TM400x2AD
Rockford Fosgate TM400x2AD I ran for 9 months, took it out when I sold my bike.
Have original receipt so factory warranty until 8/26/2018
From Fosgate website:
I'll include the power and ground cables (8 gauge), the solder on quick disconnect speaker connection (in pic), and the other plug has Stinger RCA's hard wired so you can just plug it into your LOC/DSP/Line Leveler
$300 shipped
Rockford Fosgate proprietary Class AD technology
4/2 Ohm muti-impedance Constant Power
Differential inputs with high level auto turn-on feature
8 AWG power/ground connector w/ upgraded RCA connectors
Remote-Out feature when using high level inputs
4 Ohm bridged capable
2013 PLC2 remote ready
C.L.E.A.N. input/output clip detection and indicator LEDs
Top mounted controls
Dual fan cooled
Real time thermal sensing
Dual extruded heat sinks
Discrete surface mount technology
Marine grade two part epoxy coating on circuit boards
2 Years Standard Warranty
Dual fan cooled
$300 shipped
Good amp, btw. I've got the 4 channel version running bridged. All the power you need for doggone sure. Someone should ****** this up.
Bunker (07-04-2017)
