Mark this thread as Unsold
FS: Rockford Fosgate PBR300x4 $125 shipped
PBR 300x4
Bought brand new for my Street Glide with the intent on wiring another set of rear speakers. I decided to go a different route, and not install rear speakers so went with another amp that was used and didn’t come with input/output wiring. So that is why one input/output is missing. They can be bought from RF for $20 new or cheaper on eBay. I have adjusted the price accordingly.
Amp worked fantastic and was very loud. Only reason I’m selling is because I have the other amp installed.
If you plan on only using 2 channels, you will not need the other input/output wires. If you need all 4 channels, as stated before they are $20 on RF website or can get them cheaper on EBay.
Thanks for looking and please ask any questions.
4-channel car amplifier
75 watts RMS x 4 at 4 ohms
non-bridgeable, 4-ohm stable per channel
CEA-2006 compliant
Boosted Rail amp technology
Dynamic Thermal Management cooling system
selectable high- and low-pass filters (80 Hz, 12 dB/octave)
differential-balanced inputs eliminate noise from your vehicle's electrical system
preamp and speaker-level inputs
10-gauge power and ground leads and a 30-amp fuse recommended — wiring and hardware not included with amplifier
no onboard fuses — when installing multiple amps in a system, an additional 30-amp in-line fuse between the distribution block and the amplifier is recommended
dimensions: 6-3/4"W x 1-1/2"H x 4-1/4"D
CEA-2006 compliant
SsgtScho
Audio Systems
13
01-25-2019 11:04 AM
