Mark this thread as Unsold
FS: 2 X BT355 Line Levelers
Have breakout harness connectors but could de-pin / cutoff easily. Used for 2 weeks and went with DSP. $60 each or $100 for both (shipped).
Not directly PnP since the Breakout harness has different connectors than the front speakers. If you look at the BT website they have photos of all three versions of the LL (front speaker, breakout, and universal) and you'll be able to tell the difference. However, the LL ends can be removed and easily soldered to the front speaker (Deutsch?) connectors, assuming you're using aftermarket front speakers with conventional spades directly to an amp.
I have a 2012 Street Glide with stock speakers and in the process of upgrading to a CV B52 amp and Infinity Kappa 62.11I speakers and I understand I will need a BT line leveler. WIll one of yours work? If so, I will gladly take one.
Fantozi
Audio Systems
42
06-27-2014 12:53 PM
