These are off my 98" build from my softail. They started as a set of 99-05 heads that Dan Vance Racing did his raised port jobs on. He also installed new 1.9" intake and 1.61" exhaust valves with new seals,guides and high lift valve springs. They are 81cc come with manual compression releases installed and have 5000 miles on them. Asking $500 obo shipped to you.
I ran Andrews 54 cams with these. While tearing down the motor it was discovered that the top two rings on each cylinder were installed upside down and that is the reason for the carbon in the combustion chamber.
