Heartland TC88 Inner Cam Bearing Installer & Puller for Twin Cam 88
Designed for Twin Cam Models 1999-2006.Will NOT fit 2006 Dyna. This set will remove and install the inner cam bearings on the Twin Cam 88.
I used this only once to change my inner cam bearings from cage to full complement Torrington B-148s while I was upgrading to hydraulic tensioners. No reason to go all theway in there and not do them.
This kit has both a Puller and Installer, made the job simple and allows easy pulling of the old bearing and PERFECT alignment AND seating when installing the new ones. Makes it a 15 minute job. No reason to fight it, use these tools – get it done right - then get your money back by selling it as a twice used tool.
This is the newest design and has the nice little window on top so you can see what you are doing. Very high quality and American Made.
Paid $110, will sell for $80 shipped, insured and tracked with tracking number anywhere in the lower 48.
Thumped
10-14-2013 07:01 AM
Thumped
Softail Parts
12-10-2012 02:58 PM
