Mark this thread as Unsold
Harley Davidson Repair Tools ~Sacramento~
Here is the list of part numbers and original purchase prices. Items may be purchased separately at 50% of original.
If you want the whole lot it will be $2,400. That is 60% off the original price. Most come with original packaging and are in excellent condition.
Jim's Tools:
954 Fuel pump ring remover 08-11 FL $156
753 Fly wheel lock 99-13 TC $40
959 & 956 TC Timken bearing conversion kit $950
35316-80 Main drive gear/bearing 80-04 Twin 91-03 Sportster $200
2188 58-up Evo cam bearing installer $164
5518 Shifter bushing installer 85-up rubber mounted FLH $80
1277 Cam bearing remover/installer 99-up 88TC $180
913 Wheel bearing support plate 5-7 lug cast wheels $85
1709 Timken bearing remover 86-up Flywheel $200
97225-55 55-up Sprocket Shaft bearing installer $185
22462 Timken bearing installer left crankcase twin 69-up sports 77-up $200
972 6spd TC main drive gear seal installer 06-up FXD, 07-up FXST & FL $92
963 Bearing and race puller for flywheel 03-up TC $300
739 Needle bearing remover installer counter shaft 1980-06 5-6spd $210
981 06-up Dyna 06-up XL Twin 6spd main drive gear installer $300
984 Trapdoor and gear remover 06-up Dyna and 07 FLHT & FXST $150
95760 Evo cam bearing puller $150
1276-4 Wrist pin installer remover 99-06 TC $105
2267 06-up Dyna 07-up TC Tansmission Vise stand $80
1705 Exhaust stud drill plate $105
766 Evo adapter $65
1042-8 25mm wheel bearing puller $80
33416-80-1 wheel bearing race $75
970 Axle nut holder/3rd hand 2qty $65
2251-1 Fork tube holder $100
George's Garage:
620200 6spd 06-up Dyna, 07-up TC main drive gear and bearing kit $218
320400 Torque plates 99-up TC $350
620100 91-06 Big Twin, Sports main drive gear bearing seal tool $36
620050 87-06 Twin mainshaft seal installer excpt 06 Dyna $65
620250 06-up Dyna, 07-up TC main drive gear seal installer $80
620130 Trans shaft installer 80-up big twin $ 52
620240 Drive gear seal/bearing installer 06-up Dyna, 07-up TC $69
620220 07-up trap door bearing remover/installer $110
Harley Davidson Brand Tools:
94638-08 Screaming Eagle 99-up TC compression release drill kit $260
Harley Davidson Parts:
40384-91 91-06 up big twin expt 06 Dyna Comp Socket retainer and cover assembly $140
16101-01 Screaming Eagle 99-up TC Cylinder head gasket kit $50
29229-88D Cable carburetor enricher $12
45838-77 Fork Bolts 77-99 Showa wide glide $30
Baker Tools:
T94660-37BD Socket for Trans Pulley Nut $200
Barnett:
201017 Clutch lock $20
Message or Text 9one6-three85-two38eight
Local pickup preferred, or I may deliver whole lot within 100 miles after deposit.
~Paul
Jim's Tools:
766 Evo adapter $65
George's Garage:
Baker Tools:
Barnett:
~Paul
Updated list and price.
If you want the whole lot it will be $2,366. That is 60% off the original price. Most come with original packaging and are in excellent condition.
Jim's Tools:
913 Wheel bearing support plate 5-7 lug cast wheels $85 SOLD
766 Evo adapter $65
George's Garage:
Baker Tools:
Barnett:
Local pickup preferred but can ship, or I may deliver whole lot within 100 miles after payment.
~Paul
Jim's Tools:
766 Evo adapter $65
George's Garage:
Baker Tools:
Barnett:
~Paul
Updated list and Price
If you want the whole lot it will be $2,326. That is 60% off the original price. Most come with original packaging and are in excellent condition.
Jim's Tools:
766 Evo adapter $65
2251-1 Fork tube holder $100 SOLD
George's Garage:
Baker Tools:
Barnett:
~Paul
Jim's Tools:
766 Evo adapter $65
George's Garage:
Baker Tools:
Barnett:
~Paul
Harley Davidson repair tools.
Updated list
Sold some tools, but also added some more as well....Prices as posted.
Jim's Tools:
954 Fuel pump ring remover 08-11 FL $80
753 Fly wheel lock 99-13 TC $20
959 & 956 TC Timken bearing conversion kit $600
35316-80 Main drive gear/bearing 80-04 Twin 91-03 Sportster $100
2188 58-up Evo cam bearing installer $80
5518 Shifter bushing installer 85-up rubber mounted FLH $40SOLD
1277 Cam bearing remover/installer 99-up 88TC $100
913 Wheel bearing support plate 5-7 lug cast wheels $40SOLD
1709 Timken bearing remover 86-up Flywheel $100SOLD
97225-55 55-up Sprocket Shaft bearing installer $80SOLD
22462 Timken bearing installer left crankcase twin 69-up sports 77-up $100SOLD
972 6spd TC main drive gear seal installer 06-up FXD, 07-up FXST & FL $45SOLD
963 Bearing and race puller for flywheel 03-up TC $160
739 Needle bearing remover installer counter shaft 1980-06 5-6spd $100SOLD
981 06-up Dyna 06-up XL Twin 6spd main drive gear installer $160
984 Trapdoor and gear remover 06-up Dyna and 07 FLHT & FXST $75SOLD
95760 Evo cam bearing puller $80
1276-4 Wrist pin installer remover 99-06 TC $50SOLD
2267 06-up Dyna 07-up TC Tansmission Vise stand $40SOLD
1705 Exhaust stud drill plate $50SOLD
766 Evo adapter $30
1042-8 25mm wheel bearing puller $40
33416-80-1 wheel bearing race $40
970 Axle nut holder/3rd hand $20
2251-1 Fork tube holder $50SOLD
34902-84 Removes and installs the transmission main shaft inner bearing race on Big Twin late 84-06 (except 06 Dyna models) $100
1280 Use on all Twin Cam 1999 to early 2000 for removal of bearings Use on all Late 2000-06 FXST, FL & Late 2000-05 FXD for removal of front cam bearing $100
1279 Inner Cam Bearing Remover Tool 1279 Use on all Twin Cam, 2000-06 FXST, 1999-05 FXD, and 1999-06 FL’s $ 100
George's Garage:
620200 6spd 06-up Dyna, 07-up TC main drive gear and bearing kit $100SOLD
320400 Torque plates 99-up TC $200
620100 91-06 Big Twin, Sports main drive gear bearing seal tool $25
620050 87-06 Twin mainshaft seal installer excpt 06 Dyna $40
620250 06-up Dyna, 07-up TC main drive gear seal installer $40SOLD
620130 Trans shaft installer 80-up big twin $ 30
620240 Drive gear seal/bearing installer 06-up Dyna, 07-up TC $30SOLD
620220 07-up trap door bearing remover/installer $60SOLD
94638-08 Screaming Eagle 99-up TC compression release drill kit $160
40384-91 91-06 up big twin expt 06 Dyna Comp Socket retainer and cover assembly $80
16101-01 Screaming Eagle 99-up TC Cylinder head gasket kit $30
29229-88D Cable carburetor enricher $5
45838-77 Fork Bolts 77-99 Showa wide glide $20
Baker Tools:
T94660-37BD Socket for Trans Pulley Nut $100
Barnett:
201017 Clutch lock $10
~Paul
Updated list
Jim's Tools:
766 Evo adapter $30
George's Garage:
Baker Tools:
Barnett:
~Paul
Updated List...
Prices as posted.
Jim's Tools:
766 Evo adapter $30
$100
George's Garage:
Baker Tools:
Barnett:
~Paul
Prices as posted.
Jim's Tools:
766 Evo adapter $30
$100
George's Garage:
Baker Tools:
Barnett:
~Paul
Updated List
Prices as posted.
Jim's Tools:
766 Evo adapter $30
$100
George's Garage:
Baker Tools:
Barnett:
~Paul
Prices as posted.
Jim's Tools:
766 Evo adapter $30
$100
George's Garage:
Baker Tools:
Barnett:
~Paul
Updated list:
Prices as posted.
Jim's Tools:
766 Evo adapter $30
1279 Inner Cam Bearing Remover Tool 1279 Use on all Twin Cam, 2000-06 FXST, 1999-05 FXD, and 1999-06 FL’s $100
984 Jims Dyna transmission door removal tool $110
George's Garage:
Baker Tools:
Barnett:
~Paul
Prices as posted.
Jim's Tools:
766 Evo adapter $30
George's Garage:
Baker Tools:
Barnett:
~Paul
Updated list:
Prices as posted.
Jim's Tools:
766 Evo adapter $30
George's Garage:
Baker Tools:
Barnett:
~Paul
Prices as posted.
Jim's Tools:
766 Evo adapter $30
George's Garage:
Baker Tools:
Barnett:
~Paul
