Those of you with a 14 0r 15 that has changed bars, how did you bleed the clutch? I don't have to worry about the brake because I rerouted the line and actually am going to try and do it to the clutch but may have to undo the line to reroute it. If I do what procedure did you do to bleed it and where did you bleed it at, the master or down at the trans.
Thanks
