2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Head Sets
Old 01-07-2016, 11:10 AM
sailmotion's Avatar
sailmotion
sailmotion is offline
Received 7,838 Likes on 3,236 Posts
Originally Posted by omgtkk
Let's back up a little bit. Before you start thinking about changing to earbuds or bluetooth, let's see if we can make your current headset work a little better. If you have poor sound quality and low volume with the standard Harley headsets, it's probably because the headset speakers are too far from your ears. If the drivers aren't pretty close to your ears you will have no bass response and low volume. Try taking the speakers out and putting something behind them to bring them closer to your ears without actually touching. Experiment with circles of cardboard until you find the right thickness. If that fixes your sound and volume issues, then find a way to permanently mount them and you shold be good to go. You can also go the extra step and custom cut a ring of soft foam to fill in the ear pocket in your helmet around the speaker. This will seal it better to your ear and give you much better bass. I've been using Harley and J&M headsets this way in my full and open face helmets and can't run the radio at more than about 2/3rds volume without blowing out my ears.
Hope this helps
It's fairly shocking how a few millimeters up, down, left or right makes a world of difference.
Old 01-07-2016, 11:21 AM
r2t2k2's Avatar
r2t2k2
r2t2k2 is offline
Originally Posted by sailmotion
It's fairly shocking how a few ymillimeters up, down, left or right makes a world of difference.
Good points... Sometimes even putting your helmet on a little cocked will cause a major volume change.
Old 01-07-2016, 03:50 PM
CPT_Carrera's Avatar
CPT_Carrera
CPT_Carrera is offline
Originally Posted by JD HD
You can write off Bluetooth if you are using the CB. You need to be plugged in for that.
I am using Bluetooth headset and it works for CB just fine. There are a few add-ons you can use to make this work wirelessly. The Sierra electronics mod seems to be the most popular but I use a German aftermarket device installed on my streetglide which I added CB to. Works fine but haven't used it too much.
Old 01-07-2016, 03:51 PM
CPT_Carrera
Definately what he said..
Old 01-08-2016, 07:46 AM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
I have a SHOEI GT-Air helmet, there are recesses for the speakers. The HD speakers are just a bit large, but with strategically placed velcro, they stay put, and fit nicely flush on my ears, giving excellent audio quality, both music and communication, including intercom and phone.
Old 01-12-2016, 07:44 PM
Stinkboater's Avatar
Stinkboater
Stinkboater is offline
J&M speakers are the best in my opinion. J&M sells a lower cord that has a earbud installed up near the helmet. I prefer the custom molded earbuds myself. Serve 2 purposes, blocks the wind noise and sound quality is much better.
Old 01-12-2016, 08:34 PM
Steamfighter's Avatar
Steamfighter
Steamfighter is offline
I use a set of Sena 10's. Work like a dream, no cord to get in way. I listen to the stereo thru the speakers and the wife and I talk over blue tooth. They will also work with most Bluetooth devices too. ( wife rides her own bike so needed quick and easy access to communication with out extra components etc)
Old 02-24-2016, 01:48 PM
RSDUDA's Avatar
RSDUDA
RSDUDA is offline
I am looking for a head set with smaller speakers then the Harley headset for full face they are to thick and my helmet fits to tight with them
bpav16 (05-09-2018)
Padre
16
03-31-2021 10:36 PM
bpav16
05-09-2018 01:03 PM
Sisilija
06-22-2017 09:04 AM
jrdfatboy
04-09-2013 10:04 PM
alanste
05-07-2007 11:33 PM
Quick Reply: Head Sets
