Any harm in listening to radio in ACC position
As long as it is on a battery tender you should be fine. I switch mine to AUX during rides for stops 15 minutes or less with no issues. I do this mainly so I don't lose the last satellite weather update and have to wait 15 minutes after starting again for an initial map update.
However, I put a small clock radio in my garage for just that purpose. It is a bit more comforting using the proper tool for the job
Let's see, some approximations and guesstimations if I can remember that stuff...
Standard Battery Tender, 12v at 750mA = 9 Watts
Boom Box, stock, cranked = 25 Watts/channel = 50 Watts
At "normal" volumes, probably 20 watts? (a WAG, probably a lot less.)
Typical Harley battery w/o tender; say 15 Amp Hours at 12v = 180 Watts for an hour or about 3.5 hours with sound cranked; at least 9 hours at normal volumes?
Take 9 Watts off of the 20 with the tender helping, and you're up around what, 15 hours or so?
That's the audio power, add a touch for the screen. About the same for the regular non-boom-box radios, screens don't draw much, neither does the GPS circuit.
So have a ball with your tunes. Just leave the tender on when you're done. Or better, go for a ride, my favorite way of charging the battery.
Edit: I forgot that on some bikes/trikes the tour pak lights stay on; if they're LED, no biggie, another couple of watts. Not sure about any incandescent ones.
Last edited by Oogie Wa Wa; 07-09-2015 at 08:10 PM. Reason: Forgot about tour pak lights.
Tunes on ACC
I have used the radio just as you suggest many times. There is an automatic shut off after some period of time, I wasn't paying attention to the clock so I'm not sure how long, seemed to be about an hour. It might have been more or less. I wasn't aware of the feature but it exists on my bike. After resetting the switch to OFF then back to ACC I had the radio on for about another half hour. Most of the time the radio was normal listening level, but occasionally I would crank it up for certain songs, then back down again when a commercial came on.
When finished with what I was doing I went for a ride. No problem starting up, there was plenty of power in the battery. The tender was not connected during the first time although I have connected it most other times since I have moved the bike to a more convenient location.
vtwinhd59
03-04-2012 11:41 PM
