I just finished after market radio install on a 2015 FLHTP
Very nice job! That was also one of my ?s ... whether or not you lose your air temp, oil pressure and EITMS screen, but guess not! I could care less about losing navigation since I never used it in/on any vehicle I've owned, but stupid as it sounds I like the oil press and air temp readout .... I always have that screen on after I get my favorite station on. What did all that set you back if you don't mind me asking and did you lose the use of the thumbsticks for the new set up?
The LCD display will not display Air Temp or Oil Pressure. The police bike doesn't have a oil pressure sender or ambient air sensor. You could install these, but would be more work then its worth.IMO If I didn't go with the 4.3 radio route and did a aftermarket radio I would of ditched the bottom display option.
Hello, I finished the install. I used metes kit 99-9700, kenwood marine radio, and Polk DXi 6 1/2 speakers. I had to remove the factory speaker grills because the tweeters stuck out to far. This was all done on my 2015 Police Glide. So I had no wiring harness to use. I ran power to the Battery, negative to the ground and Acc to yellow/black wire in main harness. Total cost was $340 from crutchfield. Took about 4 hours total from start to finish. I dropped the ground wire but, so I spent some time searching for it lol.
Test ride was done on I 64 at 80mph. I had no problems hearing it and it was clear. I haven't had any problem with a CD skipping. My only problem was I don't have a FM antenna yet. No one has one in stock so it's on the way. Everything from the kit worked perfectly.
