2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Police Seat
Old 09-03-2015, 06:42 PM
RK_2014's Avatar
RK_2014
RK_2014 is offline
Default Police Seat
So I have an opportunity of getting a great deal on a complete Police seat set up
It is off of a 2012 FLHP and the question I have is will bolt on/fit on my '14 Road King
Thanks
Old 09-03-2015, 07:36 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is online now
In 2012 HD still used the air spring & air tank on the police seat. The 2014 uses an adjustable spring - no air lines or tank. You can check part numbers here:
http://www.granitestateharleystore.c...14%5cSEAT%5cFH
Old 09-03-2015, 07:43 PM
RK_2014's Avatar
RK_2014
RK_2014 is offline
Thanks for the link - very well explained
2 questions then if I keep going
1 - will the seat pan etc fit
2 - can I swap out the pneumatics with the shock
Old 09-03-2015, 08:16 PM
14GuineaPig
It looks like the front bracket, the plastic frame cover (Fairing Police Seat) and the seat are the same part numbers. I THINK people have mentioned that the air spring can be replaced by the new adj. spring. Try a search, I know there are more threads about the solo / police seats. Good luck.
Old 09-03-2015, 08:44 PM
RK_2014's Avatar
RK_2014
RK_2014 is offline
Thanks Will keep looking with the additional information you provided
Old 09-04-2015, 06:04 AM
14GuineaPig
Old 09-04-2015, 06:09 AM
RK_2014's Avatar
RK_2014
RK_2014 is offline
Thank you very much - will definitely check them out !
Old 09-24-2015, 06:48 AM
RK_2014's Avatar
RK_2014
RK_2014 is offline
Update - got the set up from a member on Retired Police Bike and it was from a 2012 FLHP
Direct Install - everything lined up but i did not install the air bladder set up instead I installed a Large Kong and the ride comfort is FANTASTIC
Note that the Police seat does raise the seat level a bit so it may not be for everyone - but if you can deal with the higher seat height it is the most comfortable seat I have had on ANY bike own
Seat on Bike
Prefit check of Kong where the air shock (Coil shock) would go
Pinned in place
Old 09-24-2015, 07:16 AM
14GuineaPig
Looks good. Enjoy the ride.
Old 09-25-2015, 09:55 AM
Bafflingbs's Avatar
Bafflingbs
Bafflingbs is offline
I just did 17 hrs. on mine yesterday. That seat, is by far, the most comfortable seat you can buy. You will definitely need a tall windshield now though.
Quick Reply: Police Seat
