110 Engine vibration with rear brake
I traded my 2014 LTD for a new 2015 CVO LTD and I seem to have much more engine vibration but it is only very noticeable when using the rear brake and slowing down from 40 to about 25 mph. If I pull the clutch in and apply the rear brake it feels like a warped rotor. If I raise the RPM or shut the engine off it does not do it so I know it is from the engine. Two dealers test drove the bike and said there is a problem and one changed the rotor. They kept the bike overnight and said the next day it was normal. It has much more vibration than my 2014 and both have linked brakes so that is not the problem. Has anyone else that has changed from a 103 to the 110 found a major difference with the vibration ? Other than when using the rear brake it is a great bike. Using the front brake there is no vibration. Thanks for any replys
Mine does it too BUT it didn't start doing it until I jacked around with the engine and motor mounts trying to center the engine in the center of the doughnuts and in the frame.
So self induced in my case. I plan to dick around with it later and figure it out. Probably overly tight belt or something.
When I called Harley support and they say there is nothing they can do about it. There is no way to get a rep to look at it.Said there are only 3 reps in the whole country to cover all the dealers and are too busy to set an appointment. This is an eye opening experience for my with Harley. Could be my last Harley.
drspencer
06-19-2011 09:13 AM
bikerbehaviorist
11-01-2006 12:02 AM
