Paint Protective Film
I've got two different versions on mine on a whole bunch of surface areas.
One type is Snider's paintguard: http://www.snidersproducts.com/paint3.html
The other is a product similar to this (couldn't find the exact one in my order history): http://www.ebay.com/itm/12-x72-CLEAR...lWIHXr&vxp=mtr
The first kind is held on by static cling only, the second has a light adhesive. Both install with spray liquid and squeegee. Easy enough to do, but trimming and accurate aligning can be tricky until you get the hang of it.
It's on the bike all over:
See if you can see it...
I didn't take these photos with the intent to show off the film, but you get the idea.
All the best,
Shane
- Front fender where all the bugs hit
- Rear fender below the taillight
- Top of Tourpack
- Top, sides, front, back, and topside edges of saddlebags
- Fairing all over
- Passing lamp lenses
All the best,
Shane
Flat surfaces are fairly easy to do. Curved surfaces can be a little more difficult. Most will tend to crack and/or shrink over the years, like the old vinyl lettering you see on some trucks. The adhesive type can be a pia to remove if its been on a long time and it will leave a shadow (brighter color) if the entire surface wasn't done.
Diy
I used the 3m Scotchgard Clear Bra Paint Protection product.
I applied it to the tank where I was getting wear areas from the seat rubbing on the tank, rear fender, and side panels. You can do it yourself if you take your time and get the product really wet. Don't be afraid to peal it back and re-wet if you're not getting a good bond, bubbles etc..
Helpful install video here:
Curved surfaces are tougher than flat, and once a certain curvature gets too tight, the film will not lay down at every edge. That said, you can get a very wavy surface (like the fairing) covered with several sections that do cooperate with your squeegee.
For instance, the passing lamp lenses can be covered fairly easily, but the main headlight has a more pronounced convex surface that is all but impossible to get without wrinkles.
As to the seams...this is where your level of expertise with scissors and pattern-making are tested. On careful inspection, the seams will always be visible, so if that bothers you too much, might want to skip the whole thing.
Following the natural soft edges and flow of the bike's shapes tends to hide the edges quite well. Nobody will notice if you have nice edges trimmed to follow the contours well. Also, avoid sharp corners in your trimming--they tend to catch the eye and show up easier.
All the best,
Shane
I put the Harley kit on my saddle bag lids almost two years ago and so far it's been great. Any boot scuffs come right off without any paint damage. It was a PiTA to put on and get perfect. You really need a very dust free place to do the job and be patient getting the air bubbles out. When I first did it I wasn't happy with the he results but after a few weeks it looked much better. I guess the sun helped it really lay down and all the imperfections just disappeared .if I were doing larger sections of the bike I would probably have it done professionally
My front fairing is all one piece and covers the entire thing. If you did not know it was on there you would not see it. Do yourself a favor and get it done professionally.
